0
FreeRTOS port for Paradigm C++ V5 & V7, for Tern modules
This project demonstrates a successful port of FreeRTOS under Paradigm C++ V5 and V7 for Tern systems.  The target module used was Tern EL but the code should work on all Tern 186 systems and is readily ported to all other modules.
The README.TXT file in the ZIP contains full documentation on the modifications to the V5 project needed to successfully build FreeRTOS in V7 of the Paradigm C++ compiler.
rtos.zip
1 comment
Please sign in to leave a comment.
