Hi all,
the attached example shows two tasks blinking the LPCXpresso led via message queues.
The relevant port.c / portmacro.h files are included within the library project, based on FreeRTOS 7.0.1
Basically it should finally fix some open issues with the Cortex-M0 port as discussed in a similar (previous) post.
Kind regards,
Giancarlo
LPC11xx Cortex-M0 FreeRTOS v7.0.1 using LPCXpresso.zip
